Einleitung
This guide will show you how to fix a washer that has stopped working on your Frigidaire Laundry Center. If your washer has stopped working and won’t turn on, but your dryer is functional, then perhaps your washer has a faulty lid lock switch assembly. A faulty lid lock assembly will prevent your washer from locking up the lid/door and therefore prevent it from starting the washing cycle. If your washer won’t start and you hear a constant clicking coming from the lid/door, then it’s likely that the lid lock switch assembly is malfunctioning and therefore it must be replaced. Let me help you with this guide!
Was du brauchst
Unplug the Frigidaire Laundry Center and turn off the water supply.
Using a metal pry tool (such as a putty knife) pry open the washer's top panel.
Go around the gap of the top panel with the metal pry tool and gently lift it up.
Open the lid of the washer.
Lift up the top panel from the inside.
The lock switch assembly is underneath the right side of the top panel.
As you lift the top panel you will notice that there isn't much space. To solve this, remove the plastic clip holding the wiring harness in place with your fingers.
Lift the top panel completely and prop it open using something sturdy like a piece of wood.
Hold the switch assembly tight with one hand and remove the three electrical connectors from the assembly with the other hand.
Lift the washer lid and prop it open using something sturdy like a piece of wood.
Use a rubber hammer to gently tap the switch assembly until it slides to the front.
Remove the switch assembly.
Position the switch assembly in the slotted hole and then slide it in place until your hear a click.
Reconnect the electrical connectors using one hand to hold the switch assembly and the other to push the electrical connectors in place.
Push in the electrical connectors until you hear a click sound.
Remove the piece of wood holding the top panel in place and begin lowering it.
As you lower the top panel, reinstall the plastic clip that holds the wiring harness in place.
Align the top panel of your washer with the three clips that hold it in place and then push down until the top panel is secured and tight.
Eine weitere Person hat diese Anleitung absolviert.
