Zum Hauptinhalt wechseln
Frozen "Elsa" Singing Doll Battery Replacement
Was du brauchst
  1. Frozen "Elsa" Singing Doll Battery Replacement, Surgery!: Schritt 1, Bild 1 von 1
    • Carefully arrange Elsa's clothing so her body is accessible.
    • Find the Voice Module inside the toy's body.
    • Using a seam ripper, open Elsa up near the Voice Module.
  2. Frozen "Elsa" Singing Doll Battery Replacement, Retrieve the Voice Module: Schritt 2, Bild 1 von 1
    • Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • The Voice Module is contained inside a small cloth bag -- open it up with the seam ripper.
  3. Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: Schritt 3, Bild 1 von 2 Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: Schritt 3, Bild 2 von 2
    • Carefully pry off the top the Voice Module to expose the electronics inside.
  4. Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: Schritt 4, Bild 1 von 2 Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the worn LR41 batteries from the Voice Module electronics.
    • Replace with new LR41s, obviously!
    • Warning: button batteries are a choking hazard! Dispose of them properly, and away from children.
Abschluss
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Dom Santangelo
592 Reputation
3 Anleitungen geschrieben
Ein Kommentar
my daughter lost an Elsa like this a long time ago, would you mind sharing the name of this product or where you bought it from? Thanks
Marisol Diaz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 5,632
