Einleitung
The Fugoo Style XL has two midwoofers connected to the casing that can be removed and replaced.
Was du brauchst
Using your hand, gently lift the large plastic tab secured to the rubber holding.
After lifting the tab, slide the speaker out of its case.
There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
Carefully untangle and remove the white bundled cable connectors from the motherboard.
Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
Using your hand, carefully remove the midwoofers.
