Zum Hauptinhalt wechseln
Fugoo Style XL Speaker Replacement
Was du brauchst
  1. Fugoo Style XL Speaker Replacement, Fabric Case: Schritt 1, Bild 1 von 2 Fugoo Style XL Speaker Replacement, Fabric Case: Schritt 1, Bild 2 von 2
    • Using your hand, unscrew the large screws underneath the speaker.
  2. Fugoo Style XL Speaker Replacement: Schritt 2, Bild 1 von 3 Fugoo Style XL Speaker Replacement: Schritt 2, Bild 2 von 3 Fugoo Style XL Speaker Replacement: Schritt 2, Bild 3 von 3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  3. Fugoo Style XL Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 Fugoo Style XL Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
  4. Fugoo Style XL Speaker Replacement: Schritt 4, Bild 1 von 2 Fugoo Style XL Speaker Replacement: Schritt 4, Bild 2 von 2
    • Using your hand, pull the covers away from the speaker.
  5. Fugoo Style XL Speaker Replacement: Schritt 5, Bild 1 von 2 Fugoo Style XL Speaker Replacement: Schritt 5, Bild 2 von 2
    • Using a #2.0 Hex screwdriver to unscrew the 8 12mm screws depicted.
  6. Fugoo Style XL Speaker Replacement: Schritt 6, Bild 1 von 2 Fugoo Style XL Speaker Replacement: Schritt 6, Bild 2 von 2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
  7. Fugoo Style XL Speaker Replacement: Schritt 7, Bild 1 von 2 Fugoo Style XL Speaker Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
  8. Fugoo Style XL Speaker Replacement: Schritt 8, Bild 1 von 3 Fugoo Style XL Speaker Replacement: Schritt 8, Bild 2 von 3 Fugoo Style XL Speaker Replacement: Schritt 8, Bild 3 von 3
    • Each speaker is attached to the casing with 3mm screws. Remove the screws using a #2.0 Hex screwdriver.
    • Once the screws are removed, carefully lift the speaker from the casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
James Gifford
573 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G4, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G4, Cannon Fall 2017
USFT-CANNON-F17S3G4
4 Mitglieder
Ein Kommentar
Hello James,
Nice work. But where can I find the replacement speaker?! Best Regards
Andre Costa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 766
