Einleitung
The Fugoo Style XL has small core speakers resting within the casing that are remarkably easy to remove.
Was du brauchst
Using your hand, gently lift the large plastic tab secured to the rubber holding.
After lifting the tab, slide the speaker out of its case.
There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
Each speaker is attached to the casing with 3mm screws. Remove the screws using a #2.0 Hex screwdriver.
Once the screws are removed, carefully lift the speaker from the casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Hello James,
Nice work. But where can I find the replacement speaker?! Best Regards
