Einleitung
The two bass speakers are located on the left and right ends of the Fugoo Tough XL device.
Was du brauchst
Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
Remove the internal device from the outer casing.
Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
Use your hands to gently remove the side plates.
Use an opening tool to pry off the back plate with the Fugoo trademark.
Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
Carefully untangle the wires that connect the speaker to the motherboard.
Remove the motherboard and battery.
Remove the four 3 mm screws from the motherboard using a 3 mm Hex screwdriver.
Ein Kommentar
Hello, what is the power of this loudspeaker for resistances Ω, and RMS
