Zum Hauptinhalt wechseln
Fugoo Tough XL Battery Replacement
Was du brauchst
  1. Fugoo Tough XL Battery Replacement, Case: Schritt 1, Bild 1 von 1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Battery Replacement: Schritt 2, Bild 1 von 2 Fugoo Tough XL Battery Replacement: Schritt 2, Bild 2 von 2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Battery Replacement: Schritt 3, Bild 1 von 2 Fugoo Tough XL Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Battery Replacement: Schritt 4, Bild 1 von 3 Fugoo Tough XL Battery Replacement: Schritt 4, Bild 2 von 3 Fugoo Tough XL Battery Replacement: Schritt 4, Bild 3 von 3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Battery Replacement: Schritt 5, Bild 1 von 1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Battery Replacement, Motherboard: Schritt 6, Bild 1 von 2 Fugoo Tough XL Battery Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Carefully untangle the wires that connect the speaker to the motherboard.
  7. Fugoo Tough XL Battery Replacement: Schritt 7, Bild 1 von 2 Fugoo Tough XL Battery Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to remove the two ribbon wires on the left and right side of motherboard.
    • Do not pull the cables by the cord, as this could damage the cables and the motherboard. It is best to always disconnect the cables from the base, which is closest to the motherboard, using an iFixit opening tool.
  8. Fugoo Tough XL Battery Replacement: Schritt 8, Bild 1 von 2 Fugoo Tough XL Battery Replacement: Schritt 8, Bild 2 von 2
    • There is a hidden ribbon on the motherboard, that becomes visible once the motherboard has been pulled out.
    • Pull the motherboard halfway out.
    • Gently unplug the ribbon using tweezers.
  9. Fugoo Tough XL Battery Replacement: Schritt 9, Bild 1 von 2 Fugoo Tough XL Battery Replacement: Schritt 9, Bild 2 von 2
    • Remove the motherboard and battery.
    • Remove the four 3 mm screws from the motherboard using a 3 mm Hex screwdriver.
  10. Fugoo Tough XL Battery Replacement, Battery: Schritt 10, Bild 1 von 2 Fugoo Tough XL Battery Replacement, Battery: Schritt 10, Bild 2 von 2
    • While holding the motherboard with one hand, remove the battery.
    • Once that is completed, replace the battery with a new, functional one.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Abdul
527 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S19-G1, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G1, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G1
4 Mitglieder
5 Anleitungen geschrieben
8 Kommentare
What kind of battery is it? Which brands would be preferred? Where can I buy these batteries?
It's a good guide, but these questions remain.
Rob Robertson - Antwort
Where can I buy this battery module or the circuit board. I replaced a dead cell and charged each one individually but the circuit board has no voltage output.
Can anyone tell me the correct voltage output on each pin of the battery connector?
John Thompson - Antwort
Ciao, io ho lo stesso problema, dove posso trovare il pacco batteria oppure la scheda, perché cambiando le celle morte non ho nessuna tensione in uscita del modulo e non vengono ricaricate le batterie
Vasile Adrian Belea - Antwort
Where do you get replacement batteries? Or are they just 18650s?
Tom Evans - Antwort
i have a fugoo tough thats over 4 years old. The single battery has the following numbers on it: VPN: UP130034 M N: AE1665001 ….Made In China. UER Technology …. I was not able to find the replacement also, its 3.7v 8.70’Wh 2350 mAh, It is a 5 wire plug with a protector board ,, 2 reds, 1 white, and 2 blacks.. The darn thing about the five wires is the 2 reds and 2 blacks are soldered to one connector tab each. The 3 wire 18650 3 wires red, white,and black will work. Its only 2 mm bigger and it will fit in the original holder. Just solder the 5 wire connector to this battery by connecting both reds and blacks to the single ones and the one white to the other white.. I found the Onyx Harmon Kardon studio 2 replacement battery is perfect. Thanks, Rhett McCrady.
Rhett Mccrady - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 26
Insgesamt: 3,532
