Einleitung
This guide will show you how to remove and replace the speakers.
Was du brauchst
Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
Remove the internal device from the outer casing.
Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
Use your hands to gently remove the side plates.
Use an opening tool to pry off the back plate with the Fugoo trademark.
Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
Carefully untangle the wires that are connected from the speaker to the motherboard.
Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
Use a #3 Hex screwdriver to unscrew all six 3mm screws."
While holding the case with one hand, pull up on the speaker you wish to replace.
