Zum Hauptinhalt wechseln
FujiFilm FinePix A340 Motherboard Replacement
Was du brauchst
  1. FujiFilm FinePix A340 Motherboard Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Motherboard Replacement: Schritt 2, Bild 1 von 3 FujiFilm FinePix A340 Motherboard Replacement: Schritt 2, Bild 2 von 3 FujiFilm FinePix A340 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Motherboard Replacement: Schritt 3, Bild 1 von 2 FujiFilm FinePix A340 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Motherboard Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Motherboard Replacement: Schritt 10, Bild 1 von 2 FujiFilm FinePix A340 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the black sticky tape from the circuit board and camera case.
  11. FujiFilm FinePix A340 Motherboard Replacement: Schritt 11, Bild 1 von 2 FujiFilm FinePix A340 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing the assembly as to not break any solder leads or damage the lens assembly.
  12. FujiFilm FinePix A340 Motherboard Replacement: Schritt 12, Bild 1 von 2 FujiFilm FinePix A340 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the motherboard by pulling it straight away from the assembly.
Abschluss
Cody
47 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-11, Maness Spring 2010 Mitglied von Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 3,904
