Zum Hauptinhalt wechseln
FujiFilm FinePix S4500 Viewfinder Replacement
Was du brauchst
  1. FujiFilm FinePix S4500 Viewfinder Replacement, LCD: Schritt 1, Bild 1 von 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 6, Bild 1 von 2 FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 8, Bild 1 von 2 FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 8, Bild 2 von 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
  9. FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: Schritt 9, Bild 1 von 2 FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: Schritt 9, Bild 2 von 2
    • Remove the highlighted 2.7 mm Phillips #1 screws to release the metal cover.
  10. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 10, Bild 1 von 1
    • Turn the camera on its side and remove the highlighted 2.7 mm Phillips #1 screws.
  11. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 11, Bild 1 von 1
    • Lift and remove viewfinder cover
  12. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 12, Bild 1 von 1
    • Use the plastic opening tool to remove the ribbon wire from inside the camera
  13. FujiFilm FinePix S4500 Viewfinder Replacement: Schritt 13, Bild 1 von 1
    • Remove the viewfinder assembly from the camera
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Vicente Rios
708 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-4, Banghart Winter 2017 Mitglied von Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 893
