Einleitung
Broken viewfinder? Follow the steps below to get your camera working like new.
Was du brauchst
Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
Use a plastic opening tool to separate the back panel from the camera on the left side.
Use a plastic opening tool to separate the back panel from the camera on the bottom.
Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
Remove the highlighted 2.7 mm Phillips #1 screws to release the metal cover.
Turn the camera on its side and remove the highlighted 2.7 mm Phillips #1 screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
