Zum Hauptinhalt wechseln
FujiFilm FinePix S5100 Power Button Replacement
Was du brauchst
  1. FujiFilm FinePix S5100 Power Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Power Button Replacement: Schritt 3, Bild 1 von 1
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Power Button Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Power Button Replacement: Schritt 5, Bild 1 von 3 FujiFilm FinePix S5100 Power Button Replacement: Schritt 5, Bild 2 von 3 FujiFilm FinePix S5100 Power Button Replacement: Schritt 5, Bild 3 von 3
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Power Button Replacement: Schritt 6, Bild 1 von 3 FujiFilm FinePix S5100 Power Button Replacement: Schritt 6, Bild 2 von 3 FujiFilm FinePix S5100 Power Button Replacement: Schritt 6, Bild 3 von 3
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
  6. FujiFilm FinePix S5100 Power Button Replacement, Power Button: Schritt 7, Bild 1 von 3 FujiFilm FinePix S5100 Power Button Replacement, Power Button: Schritt 7, Bild 2 von 3 FujiFilm FinePix S5100 Power Button Replacement, Power Button: Schritt 7, Bild 3 von 3
    • Use caution when removing the power button chip because the opposite end of the white digital tape may be pulled out from the receiving port.
    • Using your hand, gently grab the back of the power button chip from underneath the actual power button.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 29
Insgesamt: 774
