Einleitung
If your camera case has scratches or dents, it can be replaced by unscrewing the case of it. You need to take out some screws on the left side, right side and bottom part.
Was du brauchst
Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
Take the two screws on the left side and the two screws on the bottom of the camera.
By now you will have the front case and the back case separated from each other.
