Einleitung
Use this guide to replace the battery door.
Was du brauchst
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Locate the latch on the battery door.
Use your finger pry to it open where it says "BATT."
Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
Squeeze the camera placing a thumb on the tab marked CE.
Pull the back half of the camera firmly away from the camera body.
Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
The plastic strip will now come off the camera body.
