Zum Hauptinhalt wechseln
Fujifilm Endeavor 100ix Battery Door Replacement
Was du brauchst
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: Schritt 1, Bild 1 von 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 3, Bild 1 von 1
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 5, Bild 1 von 1
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 6, Bild 1 von 1
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 7, Bild 1 von 2 Fujifilm Endeavor 100ix Battery Door Replacement: Schritt 7, Bild 2 von 2
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
Abschluss
Eric Nicolai
679 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-5, Forte Winter 2011 Mitglied von Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,863
