Einleitung
This guide explains how to replace the old broken LCD screen.
Was du brauchst
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
The cover will pop out.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
