Zum Hauptinhalt wechseln
Fujifilm FinePix 4700 Zoom Back Cover Replacement
Was du brauchst
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 3, Bild 1 von 3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 3, Bild 2 von 3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 4, Bild 1 von 2 Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
Abschluss
Sarthak Patel
10 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-8, Forte Spring 2012 Mitglied von Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
5 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 27
Insgesamt: 1,315
