Zum Hauptinhalt wechseln
Fujifilm FinePix F505EXR Battery Replacement
Was du brauchst
  1. Fujifilm FinePix F505EXR Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Fujifilm FinePix F505EXR Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Battery Replacement: Schritt 2, Bild 1 von 2 Fujifilm FinePix F505EXR Battery Replacement: Schritt 2, Bild 2 von 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Battery Replacement: Schritt 3, Bild 1 von 2 Fujifilm FinePix F505EXR Battery Replacement: Schritt 3, Bild 2 von 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
Abschluss
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G6, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 1,207
