Zum Hauptinhalt wechseln
Fujifilm FinePix F505EXR Selector Button Replacement
Was du brauchst
  1. Fujifilm FinePix F505EXR Selector Button Replacement, Battery: Schritt 1, Bild 1 von 2 Fujifilm FinePix F505EXR Selector Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 2, Bild 1 von 2 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 2, Bild 2 von 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 3, Bild 1 von 2 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 3, Bild 2 von 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
  4. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: Schritt 5, Bild 1 von 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: Schritt 5, Bild 2 von 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: Schritt 5, Bild 3 von 3
    • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
    • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
    • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
  5. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 6, Bild 1 von 2 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
    • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
    • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
    • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
    • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
  6. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
    • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
  7. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 8, Bild 1 von 3 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 8, Bild 2 von 3 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 8, Bild 3 von 3
    • Lift the chip with tweezers to remove it from the other remaining components.
  8. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button: Schritt 9, Bild 1 von 1
    • After the selector button circuit board is taken out. There will be a black rubber display for the front buttons, remove this.
  9. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 10, Bild 1 von 2 Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 10, Bild 2 von 2
    • After taking the rubber button selector out, there will still be a circular metal selector button. This is what makes the camera delete pictures and do various tasks. Remove this and set aside.
  10. Fujifilm FinePix F505EXR Selector Button Replacement: Schritt 11, Bild 1 von 1
    • Finally replace the selector button with the new replacement.
Abschluss
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G6, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 381
