Zum Hauptinhalt wechseln
Fujifilm FinePix HS30EXR Discharge Flash Replacement
Was du brauchst
  1. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Frame: Schritt 1, Bild 1 von 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 3, Bild 1 von 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 4, Bild 1 von 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 5, Bild 1 von 1
  6. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 6, Bild 1 von 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 7, Bild 1 von 2 Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 7, Bild 2 von 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 9, Bild 1 von 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 11, Bild 1 von 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 12, Bild 1 von 1
  13. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 13, Bild 1 von 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 14, Bild 1 von 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Discharge Flash Replacement: Schritt 15, Bild 1 von 1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Discharge Flash: Schritt 16, Bild 1 von 1
    • Remove the discharge flash by giving it a light tug. It is held in place with glue.
    • Replace the old flash bulb with a new one, and begin the reconstruction of the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Baylor, Team S1-G2, Williams Fall 2018 Mitglied von Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 761
