Zum Hauptinhalt wechseln
Fujifilm FinePix HS30EXR Frame Replacement
Was du brauchst
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: Schritt 1, Bild 1 von 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 3, Bild 1 von 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 4, Bild 1 von 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 5, Bild 1 von 1
  6. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 6, Bild 1 von 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: Schritt 7, Bild 1 von 2 Fujifilm FinePix HS30EXR Frame Replacement: Schritt 7, Bild 2 von 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
Abschluss
Baylor, Team S1-G2, Williams Fall 2018 Mitglied von Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 773
