Zum Hauptinhalt wechseln
Fujifilm FinePix S1 EVF/LCD Button Replacement
Was du brauchst
  1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: Schritt 1, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: Schritt 1, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: Schritt 1, Bild 3 von 3
    • Remove the 7 screws on the perimeter of the camera body.
  2. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 2, Bild 3 von 3
    • Remove the flash accessory cap.
    • Remove the spacer covering the screws under the flash accessory cap.
  3. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 3, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 3, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the 4 screws from the inside of the flash accessory slot.
    • Pull off the flash accessory slot.
  4. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 4, Bild 1 von 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 4, Bild 2 von 2
    • Remove the screw from LCD Screen hinge cover.
    • Remove the LCD Screen hinge cover.
  5. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 5, Bild 3 von 3
    • Remove the 3 screws located on the LCD screen hinge.
    • Remove the caps from both ends of the LCD screen hinge by lifting them off.
  6. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 6, Bild 1 von 1
    • Remove the 2 screws from under the LCD hinge caps.
  7. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 7, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 7, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 7, Bild 3 von 3
    • Pry apart the back body from the rest of the camera.
  8. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 8, Bild 1 von 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 8, Bild 2 von 2
    • Carefully pull the back body off of the camera.
    • Make sure to not yank off the connections from the body to the motherboard.
  9. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 9, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 9, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 9, Bild 3 von 3
    • Use a spudger to lift up on the tab, releasing the yellow wire strip.
    • Use a spudger to lift up on the side tab, releasing the blue wire connection.
  10. Fujifilm FinePix S1 EVF/LCD Button Replacement, EVF/LCD Button Cover: Schritt 10, Bild 1 von 1
    • Remove 2 screws from back of EVF/LCD button.
  11. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 11, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 11, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 11, Bild 3 von 3
    • Pull EVF/LCD button frame out from the camera casing.
  12. Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 12, Bild 1 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 12, Bild 2 von 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: Schritt 12, Bild 3 von 3
    • Pull button cover off of the button frame.
Abschluss
USF Tampa, Team 3-6, Sullivan Spring 2016 Mitglied von USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 1,147
