Was du brauchst
Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
Remove the three screws holding the LCD screen in place.
Replace with new screen.
Remove the two screws from underneath the flash mechanism.
Remove the two screws placed on the right and left sides of the camera.
Remove two silver plated screw from under the top of the camera, under the flash.
