Einleitung
If your camera will not start, replacing the batteries might be a good solution.
Begin with the camera upside down so that the battery compartment is showing.
Slide the latch down towards the lens.
Push the battery cover out to the right, toward the HDMI and USB ports.
Lift the battery cover up so that you can view all four batteries.
Remove the batteries from the compartment.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
