Einleitung
Use this guide to replace the lense in the Fujifilm Finepix S4200. This guide requires the use of a Phillips 000 screwdriver and soldering iron. Previous soldering experience is recommended.
Was du brauchst
Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
Remove casing part pictured by gently pulling up until casing is fully detached.
Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
Remove the top casing by pulling upwards.
Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
Using a Phillips #000 screwdriver, remove the 10mm screws.
