Zum Hauptinhalt wechseln
Fujifilm FinePix S4800 Battery Replacement
  1. Fujifilm FinePix S4800 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix S4800 Battery Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix S4800 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S19-G4, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 44
Insgesamt: 3,616
