Einleitung
Lots of things could cause your LCD screen to need replacing. Here's how to do it.
Was du brauchst
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Fold back the LCD screen with the plastic opening tool.
Remove the cable coming from the LCD screen that goes into the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
