Zum Hauptinhalt wechseln
Fujifilm FinePix S8200 Rear Housing Cover Replacement
Was du brauchst
  1. Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 2, Bild 1 von 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 3, Bild 1 von 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: Schritt 4, Bild 1 von 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: Schritt 4, Bild 2 von 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: Schritt 4, Bild 3 von 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 5, Bild 3 von 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: Schritt 6, Bild 1 von 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
Abschluss
Marcos
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 7-1, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 962
