Einleitung
The rear housing cover protects the back of the camera. If the rear housing cover is cracked or damaged, it should be replaced.
Was du brauchst
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Fast fertig!
Abschluss
