Zum Hauptinhalt wechseln
Fujifilm FinePix S8200 Selector Replacement
Was du brauchst
  1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Selector  Replacement: Schritt 2, Bild 1 von 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Selector  Replacement: Schritt 3, Bild 1 von 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: Schritt 4, Bild 1 von 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: Schritt 4, Bild 2 von 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: Schritt 4, Bild 3 von 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Selector  Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix S8200 Selector  Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix S8200 Selector  Replacement: Schritt 5, Bild 3 von 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Selector  Replacement: Schritt 6, Bild 1 von 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: Schritt 7, Bild 1 von 1
    • To Replace the Selection button, carefully pull the button until the button has been fully detached.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 7-1, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,129
