Zum Hauptinhalt wechseln
Fujifilm FinePix S8630 Button Panel Replacement
Was du brauchst
  1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: Schritt 1, Bild 1 von 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 2, Bild 1 von 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 3, Bild 1 von 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 4, Bild 1 von 2 Fujifilm FinePix S8630 Button Panel Replacement: Schritt 4, Bild 2 von 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 5, Bild 1 von 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 6, Bild 1 von 3 Fujifilm FinePix S8630 Button Panel Replacement: Schritt 6, Bild 2 von 3 Fujifilm FinePix S8630 Button Panel Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Button Panel Replacement: Schritt 7, Bild 1 von 3 Fujifilm FinePix S8630 Button Panel Replacement: Schritt 7, Bild 2 von 3 Fujifilm FinePix S8630 Button Panel Replacement: Schritt 7, Bild 3 von 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: Schritt 8, Bild 1 von 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: Schritt 8, Bild 2 von 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: Schritt 8, Bild 3 von 3
    • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
Abschluss
USF Tampa, Team 3-2, Sullivan Spring 2016 Mitglied von USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 377
