Zum Hauptinhalt wechseln
Fujifilm FinePix S9500 Command Dial Replacement
Was du brauchst
  1. Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: Schritt 1, Bild 1 von 3 Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: Schritt 1, Bild 2 von 3 Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: Schritt 1, Bild 3 von 3
    • Locate and remove two screws. They are M1.7 x 5.0 in size.
    • The first screw is below and to the left of the command dial on the back of the camera.
    • The second screw is on the right side of the camera, to the right of the strap mount.
  2. Fujifilm FinePix S9500 Command Dial Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 2, Bild 3 von 3
    • To access the flash on the camera, locate the button on the left side and press it to open.
    • It's important to have the flash open to avoid any interference during disassembly.
  3. Fujifilm FinePix S9500 Command Dial Replacement: Schritt 3, Bild 1 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 3, Bild 2 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 3, Bild 3 von 3
    • To open the case, gently push upward in the area just below the command dial with your thumb.
    • The top should pop up, but not fully detach.
    • To release the catch located on the left of the command dial and at the base of the flash, place your thumb to the right of the command dial and push upwards at a 45° angle towards the flash.
  4. Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: Schritt 4, Bild 1 von 3 Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: Schritt 4, Bild 2 von 3 Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: Schritt 4, Bild 3 von 3
    • Remove the four Phillips screws (M1.7 x 5.0) on the back of the metal bracket.
  5. Fujifilm FinePix S9500 Command Dial Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix S9500 Command Dial Replacement: Schritt 5, Bild 3 von 3
    • Remove the metal assembly that has been released by the screws.
Abschluss
Ben Stevens
292 Reputation
3 Anleitungen geschrieben
Casper College, Team 1-1, Lareau Spring 2023 Mitglied von Casper College, Team 1-1, Lareau Spring 2023
CASC-LAREAU-S23S1G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 181
