Einleitung
If your Fujifilm FinePix T500 is producing blurry images or is cracked or broken, use this guide to replace the camera lens. The camera lens transmits light to a fixed focal point. A faulty camera lens will transmit dark images, or no images at all. Fortunately, the camera lens can be replaced in just a few steps. It is important to approach the repair with proper techniques and tools to ensure a smooth replacement.
Was du brauchst
Open the battery chamber and remove the battery.
Pry the front half of the casing from the camera.
Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
Lift the LCD screen out of the camera.
There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
Pry the center casing off the camera. This is best done by separating the top and side sections individually.
Peel back the strip of black tape to reveal a red and black wire.
Detach the orange ribbon by gently pulling on it.
Detach the golden ribbon by gently lifting it with the spudger.
The lens should now be free to simply be pushed out of its socket.
The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
