Einleitung
This guide will enable the user to replace the back panel buttons in the FujiFilm FinePix XP70.
Was du brauchst
Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
Remove one Phillips screw with a Phillips head 0 screwdriver
Remove one hex head screw with a hex 1.3 screwdriver bit.
Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
