Einleitung
Water may get trapped within the casing of the camera, and to prevent further damage, removing the panels allows for cleaning the camera inside and out. These panels can also be replaced if they are cracked, which allows water to seep in.
Was du brauchst
Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
Remove one Phillips screw with a Phillips head 0 screwdriver
Remove one hex head screw with a hex 1.3 screwdriver bit.
Ein Kommentar
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
