Zum Hauptinhalt wechseln
Fujifilm FinePix XP70 Front and Back Panel Replacement
Was du brauchst
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 2, Bild 1 von 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 3, Bild 1 von 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: Schritt 4, Bild 1 von 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 5, Bild 1 von 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 6, Bild 1 von 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 7, Bild 1 von 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 8, Bild 1 von 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 8, Bild 2 von 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 9, Bild 1 von 1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 10, Bild 1 von 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 10, Bild 2 von 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: Schritt 10, Bild 3 von 3
    • Pry the back plate off with a plastic opening tool
Abschluss
Olivia A
484 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S7-G3, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S7-G3, Julie Spring 2017
UMASSD-JULIE-S17S7G3
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 439
