Zum Hauptinhalt wechseln
Fujifilm FinePix XP80 LCD Screen Replacement
Was du brauchst
  1. Fujifilm FinePix XP80 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Fujifilm FinePix XP80 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Fujifilm FinePix XP80 LCD Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 LCD Screen Replacement, Exterior Case: Schritt 3, Bild 1 von 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 9, Bild 1 von 2 Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 LCD Screen Replacement, Interior Case: Schritt 10, Bild 1 von 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 12, Bild 1 von 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 13, Bild 1 von 3 Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 13, Bild 2 von 3 Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 13, Bild 3 von 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 14, Bild 1 von 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 LCD Screen Replacement, LCD Screen: Schritt 15, Bild 1 von 1
    • Once you expose the inside of the camera, use the PH000 Phillips head bit and remove the four screws as shown.
    • Carefully remove the tape binding the screen to the camera.
  16. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 16, Bild 1 von 1
    • Gently pry the LCD screen from the case, using a plastic opening tool.
  17. Fujifilm FinePix XP80 LCD Screen Replacement: Schritt 17, Bild 1 von 1
    • Unclip the LCD data line from the mother board, using the plastic opening tool.
Abschluss
Daniela Pesci
194 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-3, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 566
