Zum Hauptinhalt wechseln
Fujifilm FinePix Z5 LCD Screen Replacement
Was du brauchst
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
Abschluss
James Madison, Team 3-4, Klein Spring 2012 Mitglied von James Madison, Team 3-4, Klein Spring 2012
JMU-KLEIN-S12S3G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 964
