Zum Hauptinhalt wechseln
Fujifilm Finepix F10 6.3 MP Flash Battery Replacement
Was du brauchst
  1. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 4, Bild 1 von 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 4, Bild 2 von 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 4, Bild 3 von 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Front cover: Schritt 5, Bild 1 von 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 6, Bild 1 von 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 7, Bild 1 von 2 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: Schritt 7, Bild 2 von 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: Schritt 8, Bild 1 von 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: Schritt 8, Bild 2 von 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: Schritt 8, Bild 3 von 3
    • Gently remove battery from casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sarah Looper
100 Reputation
7 Anleitungen geschrieben
Clemson, Team 13-4, Benson Spring 2013 Mitglied von Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
What is the battery number so you can have a replacement ready?
attic77 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 20
Insgesamt: 694
