Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
This guide will explain how to remove the front cover from the camera. This is the cover that surrounds the lens side of the camera. Removing screws from the motherboard will allow the front casing to be removed.
  1. Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Remove screws from motherboard using the Phillips 00 screwdriver.
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard. Do not be alarmed if it takes substantial pressure to separate the two.
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sarah Looper
76 Reputation
7 Anleitungen geschrieben
Clemson, Team 13-4, Benson Spring 2013 Mitglied von Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 602
