Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A guide on how to take out the many screws located on the inside, metal cover and how to install an LCD.
  1. Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Slide casing out using the spudger.
    • Slide casing out using the spudger.
  7. Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out. Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sarah Looper
76 Reputation
7 Anleitungen geschrieben
Clemson, Team 13-4, Benson Spring 2013 Mitglied von Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Mitglieder
16 Anleitungen geschrieben
Great Guide! Worked great to replace my screen!
Daniel - Antwort
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Antwort
Shutter button replacement was great too!
Daniel -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 734
