Zum Hauptinhalt wechseln
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
Was du brauchst
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 2, Bild 1 von 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 3, Bild 1 von 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 4, Bild 1 von 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 4, Bild 2 von 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 4, Bild 3 von 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: Schritt 5, Bild 1 von 2 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: Schritt 5, Bild 2 von 2
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 6, Bild 1 von 1
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: Schritt 7, Bild 1 von 1
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sarah Looper
100 Reputation
7 Anleitungen geschrieben
Clemson, Team 13-4, Benson Spring 2013 Mitglied von Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 813
