Einleitung
Before you get started with this procedure, have a place to store screws in an organized fashion. There are many screws involved in this procedure that you don't want to get mixed up.
Was du brauchst
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
Once you unscrew all of the screws, carefully remove the rear casing.
Detach the ribbon cable by lifting the tab on the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
