Einleitung
This repair guide will show you how to properly remove the shell of the Fujifilm Instax Mini 70. No special skills required.
Was du brauchst
Look at the bottom of the camera and find the four 6 mm Phillips #0 screws and remove them.
Use a jimmy to separate the front and back shells. Then, use your hands to gently pull the back shell away from the front until it fully detaches.
Fast fertig!
Abschluss
