Zum Hauptinhalt wechseln
Fujifilm Instax Minion Camera Shell Replacement
Was du brauchst
  1. Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: Schritt 1, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: Schritt 1, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: Schritt 1, Bild 3 von 3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Camera Shell Replacement: Schritt 2, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 2, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Camera Shell Replacement: Schritt 3, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 3, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 3, Bild 3 von 3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Camera Shell Replacement: Schritt 4, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 4, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 4, Bild 3 von 3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Camera Shell Replacement: Schritt 5, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 5, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Camera Shell Replacement: Schritt 6, Bild 1 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 6, Bild 2 von 3 Fujifilm Instax Minion Camera Shell Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
Abschluss
Jonnah Lee
473 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S18-G6, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G6
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 29
Insgesamt: 2,075
