Einleitung
In this guide you will need two tools: a Phillips #00 screwdriver and a soldering iron. Take caution when taking out the bulb especially if the capacitor is in tact, you may get shocked if you touch it.
Was du brauchst
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Use a spudger to remove the film slot guard on the top of the camera.
Remove the one 4.5 mm #00 Phillips screw under the slot guard.
Press the release tab on the back of the camera to open the film compartment.
Remove the film cartridge within this compartment.
Use a plastic opening tool to help pry the front and back shells apart.
With the camera facing down, remove only the back shell.
Carefully peel the front side of the shell away.
Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
Once the shell is off, remove the one 6.5 mm screw that is attached to the flash bulb using a Phillips #00 screwdriver.
Remove the flash bulb from the circuit board by shifting it towards the side with the motor and lifting.
Place the bulb over an open surface and use the soldering gun to melt the three connections off the bulb.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
Hi, does anyone know how to find replacement bulb?
same question here!
Hi, I did bulb replacement on Mini 40 with the help of this guide. I found similar looking bulb on Aliexpress. I suggest you to look online for a replacement xenon tube lamp that is similar in look and length. I found lamp for Nikon models ******D40 D40X D60 D60X D3000 fitting and working fine with Instax Mini 40
