Einleitung
This guide instructs you on how to replace the motor that ejects the film. You will need a Phillips screwdriver and a soldering iron.
Was du brauchst
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Use a spudger to remove the film slot guard on the top of the camera.
Remove the one 4.5 mm #00 Phillips screw under the slot guard.
Press the release tab on the back of the camera to open the film compartment.
Remove the film cartridge within this compartment.
Use a plastic opening tool to help pry the front and back shells apart.
With the camera facing down, remove only the back shell.
Carefully peel the front side of the shell away.
Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Can anyone help finding a motor for the instax 8 or 9? I can't find one to fit any help appreciated
