Zum Hauptinhalt wechseln
Fujifilm X-M1 Disassembly
Was du brauchst
  1. Fujifilm X-M1 Disassembly, Fujifilm X-M1 Disassembly: Schritt 1, Bild 1 von 1
    • If you haven't done so already, remove the lens from the camera.
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  2. Fujifilm X-M1 Disassembly: Schritt 2, Bild 1 von 1
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  3. Fujifilm X-M1 Disassembly: Schritt 3, Bild 1 von 1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  4. Fujifilm X-M1 Disassembly: Schritt 4, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 4, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 4, Bild 3 von 3
    • Remove the six 6.5 mm Phillips screws from the lens mount.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
  5. Fujifilm X-M1 Disassembly: Schritt 5, Bild 1 von 1
    • Remove the four 4.3 mm screws securing the sensor to the front case.
  6. Fujifilm X-M1 Disassembly: Schritt 6, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 6, Bild 2 von 2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  7. Fujifilm X-M1 Disassembly: Schritt 7, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 7, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 7, Bild 3 von 3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  8. Fujifilm X-M1 Disassembly: Schritt 8, Bild 1 von 1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  9. Fujifilm X-M1 Disassembly: Schritt 9, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 9, Bild 2 von 2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  10. Fujifilm X-M1 Disassembly: Schritt 10, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 10, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 10, Bild 3 von 3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  11. Fujifilm X-M1 Disassembly: Schritt 11, Bild 1 von 1
    • Slide the frame around the LCD to remove it from the camera.
  12. Fujifilm X-M1 Disassembly: Schritt 12, Bild 1 von 1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  13. Fujifilm X-M1 Disassembly: Schritt 13, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 13, Bild 2 von 2
    • Use tweezers to unhook the speaker near the left handgrip.
  14. Fujifilm X-M1 Disassembly: Schritt 14, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 14, Bild 2 von 2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  15. Fujifilm X-M1 Disassembly: Schritt 15, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 15, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 15, Bild 3 von 3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
  16. Fujifilm X-M1 Disassembly: Schritt 16, Bild 1 von 1
    • Use tweezers to remove the three pieces of tape covering the components of the motherboard.
  17. Fujifilm X-M1 Disassembly: Schritt 17, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 17, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 17, Bild 3 von 3
    • Desolder the three pairs of red and black wires attached to the mother board.
    • Learn more about desoldering wires here.
  18. Fujifilm X-M1 Disassembly: Schritt 18, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 18, Bild 2 von 2
    • Use tweezers to remove the grey cushion located below the flash button.
  19. Fujifilm X-M1 Disassembly: Schritt 19, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 19, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 19, Bild 3 von 3
    • Use two fingers to remove the two ribbon cables in the bottom left corner of the motherboard.
  20. Fujifilm X-M1 Disassembly: Schritt 20, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 20, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 20, Bild 3 von 3
    • Use the flat end of a spudger to unlock the four indicated ZIF connectors.
    • Use two fingers to pull the ribbon cables out of the connectors.
  21. Fujifilm X-M1 Disassembly: Schritt 21, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 21, Bild 2 von 2
    • Remove the 3.3 mm Phillips screw from the upper left corner of the motherboard.
    • Remove the 2.4 mm Phillips screw in the bottom right corner of the motherboard.
    • Use two fingers to remove the motherboard from the front case.
  22. Fujifilm X-M1 Disassembly: Schritt 22, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 22, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 22, Bild 3 von 3
    • Use tweezers to remove the black plastic tape at the top of the battery compartment.
    • Insert a Phillips #00 screwdriver through the hole beneath the black tape to remove a 4.8 mm screw.
    • Insert a Phillips #00 screwdriver through the white tamper evident sticker to remove a second 4.8 mm screw.
  23. Fujifilm X-M1 Disassembly: Schritt 23, Bild 1 von 1
    • Remove the 3.7 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 4.2 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 6.2 mm Phillips screw hiding between the sensor mount and the battery compartment.
  24. Fujifilm X-M1 Disassembly: Schritt 24, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 24, Bild 2 von 2
    • Press the flash button to release the flash assembly.
    • Remove the 3.4 mm Phillips screw in the back of the flash compartment.
  25. Fujifilm X-M1 Disassembly: Schritt 25, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 25, Bild 2 von 2
    • Remove the top plate.
  26. Fujifilm X-M1 Disassembly: Schritt 26, Bild 1 von 1
    • Remove the sensor assembly.
  27. Fujifilm X-M1 Disassembly: Schritt 27, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 27, Bild 2 von 2
    • Remove the battery compartment.
  28. Fujifilm X-M1 Disassembly: Schritt 28, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 28, Bild 2 von 2
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
  29. Fujifilm X-M1 Disassembly: Schritt 29, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 29, Bild 2 von 2
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
  30. Fujifilm X-M1 Disassembly: Schritt 30, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 30, Bild 2 von 2
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
  31. Fujifilm X-M1 Disassembly: Schritt 31, Bild 1 von 2 Fujifilm X-M1 Disassembly: Schritt 31, Bild 2 von 2
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
  32. Fujifilm X-M1 Disassembly: Schritt 32, Bild 1 von 3 Fujifilm X-M1 Disassembly: Schritt 32, Bild 2 von 3 Fujifilm X-M1 Disassembly: Schritt 32, Bild 3 von 3
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
  33. Fujifilm X-M1 Disassembly: Schritt 33, Bild 1 von 1
    • Remove the LCD from the screen cover.
  34. Fujifilm X-M1 Disassembly: Schritt 34, Bild 1 von 1
    • You have successfully disassembled the Fujifilm X-M1!
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kelsea Weber
19.362 Reputation
32 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
136 Mitglieder
15.177 Anleitungen geschrieben
7 Kommentare
what about the top plate??? no one apparently knows how to remove the rotary switches from the upper assembly. Still looking for someone to show how those things are assembled
Juan Paz - Antwort
Hi, I have disassembled in more detail the whole camera and collected in reverse order to every detail , I can send you my photos for a complete collection of disassembly of the camera, my email: tyapa141465@mail.ru
Felus Felus - Antwort
Great article.
I have disassembled mine in order to clean dust inside sensor assembly, i took apart #26 using top 2 screws and the bottom one.
Unfortuntatly in the middle there were spacers, on the bottom 3 of them, on the upper side i have found 5 little metal spacers… without knowing how many were on the left, and on the right. Do you have pictures of this stage? Tya.
Francesco - Antwort
Большое спасибо автору статьи. Благодаря ей разобрали Fuji X-A2 для ремонта (после падения камеры не работала часть функций). После разборки и последующей сборки камера работает как новая. Только черную пленку под LCD пришлось выбросить, потому что она одноразовая
Lena Raigorodskiy - Antwort
Many thanks to the author of the article. Thanks to her dismantled Fuji X-A2 for repair (after the fall of the camera did not work part of the functions). After disassembly and subsequent Assembly, the camera works as new. Only the black film under the LCD had to be thrown away, because it is disposable
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 84
Insgesamt: 10,756
