Zum Hauptinhalt wechseln
Fujifilm XP20 Battery Replacement
  1. Fujifilm XP20 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Fujifilm XP20 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Fujifilm XP20 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open.
  2. Fujifilm XP20 Battery Replacement: Schritt 2, Bild 1 von 1
    • Now that the hatch is open, you should be able to see the battery. To take out the old battery, just push down on it and then it will slightly eject itself, making it possible for you to grab with your finger tips.
    • At this point, this battery cannot be used again, be sure to dispose of it in a proper manner.
Abschluss
Craig Swartz
101 Reputation
1 Anleitung geschrieben
IUPUI, Team 1-1, Wilson Fall 2016 Mitglied von IUPUI, Team 1-1, Wilson Fall 2016
IUPUI-WILSON-F16S1G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 34
Insgesamt: 1,057
