Einleitung
Replacing the battery for the Fujitsu Lifebook U810 is a simple process that does not require a toolkit of any kind. This guide helps repair a short battery life for the device and can improve the overall lifespan. You can find a new battery online by searching the model number and corresponding part for the U810 model.
Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side.
Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device.
